- May 11, 2021
- 34
- Plaster
- Pentair Intellichlor IC-40
I never did get to the bottom of my suction side Leak. I'm about resolved to go ahead and just chop off the plumbing basically at ground level and replace everything upstream of the pump (including 3 way valve).
I'm thinking of up sizing to 2" right from the ground. I can't imagine that's a bad idea, but is it a good idea? Or negligible? Also, I'll be replumbing the pressure side after the valve because my Polaris booster pump inlet needs to come from pool return only. Same question here - is it worthwhile to upsize to 2"?
Also, I'd like to get a longer straight run prior to the pump inlet, so I was thinking of using 3 45s instead of a 90 to back the valve away from the pump (don't have much real estate to just move the pump back). Does that seem like a good idea? Tried to illustrate my idea, but had to do it at ground level to keep a free hand to take the pic - hopefully it makes sense what I'm going for. Would adding an otherwise unnecessary 45 be worthwhile to extend my straight run after the valve? Either way, I'm getting rid of the pointless offset dogleg thing they did with 2 45s in the current plumbing.
