TF-100 arrived today. I am adjusting PH down to between 7.2-7.5 and will commence SLAMming.
Perfect. Thank you.First change. Ignore what test samples do after sitting around.
Once I get to the end of the night. I will get it back to slam level before bed, then do the OCLT?Good work!
Makes sense. Thanks, you cleared up exactly my confusion.I'm not 100% sure about that but it's often advised here. I believe it's due to the amount of drops needed at high FC levels, and while SLAM 1ppm more FC isn't going to break anything for the OCLT you're looking for <1ppm loss to be able to pass.
Test again when you get home, and if the FC is still close to 28 I'd think you're ready for OCLT. Even if you do lose >1ppm, it's probably just one more day. Quite honestly, the idea of letting FC drop to 10ppm to be able to do the OCLT is contrary to the SLAM process which states that you maintain SLAM level till you pass the 3 criteria.
I think I would default to doing OCLT at SLAM level, and just be very diligent about dropping and swirling simultaneously (or speedstir).
Beautiful pool! I agree, very clear.
Shrug... try OCLT and see what happens. Have you checked/cleaned all you nooks and crannies (lights, steps, handrail, etc.) where algae could hide?
I'd keep bumping up to SLAM level tonight till you go to bed, then test one more time after adding to verify FC and then check in the AM. Baby SLAMs of 1-3 days aren't unheard of.
Yeah. I’ve brushed. And ran the robot. The water is crystal clear all the way down to 8 feet. Like a postcard. Have never had any issues with that.
I’ll test again here at 8:15. Bump up if I need to. Then check again in the morning before sun up.
