I've been having an ongoing battle keeping my FC over 2 from day to day.
Having a stock tank which is much smaller and different material (galvanized steel) than 99.9% pools in this forum, makes me the pioneer of finding the best chemical balancing for this pool.
Good News is that all the levels are good every week that I do the full TFTestKit.
Bad News is my FC drops too much from day to day.
My theory was between only having about 750 gallons, being in direct sunlight dawn to dusk, and having a metal surface that reflect rays, my FC just gets eaten like Mayweather did with McGregors punches.
So for the past few weeks, I've been upping my CYA by 10 each time. Started off at around 20, went to 30, then 40, and this past Friday added enough to bring to 50. Didn't test again, but FC still dropped below 2 (.5 to be exact). So added enough for 60 just now.
This morning's FC test was encouraging with the .5 FC as it pretty much usually was at 0 every day leading up. (yes I've shocked and did ONFC test before and it's not contaminants)
My added theory is that being as small as it is, there's water being splashed out, thanks toddlers, and refilled occasionally. Plus the Sunshine State's frequent rainfall that adds to it.
I'm not sure what else to do except keep bringing up CYA until daily FC does not drop under 2 and settle with the fact that my pool will be a bit more high maintenance with the specs listed above.
Any thoughts?
Any thoughts?
