My FC tested at 6.5ppm 3 days ago and now it is testing at 13 or 13.5. I haven't touched the chemicals at all and we have a SWG running at 40% whenever the filter runs. Normally the filter is run from 9am-4pm daily unless I need to circulate water longer or overnight.
The only two factors over the last 3 days that may contribute are:
1. I've been using our hose water and spraying thousands of microscopic springtails into the skimmer port over the past 2 days - lots of random spraying of the pool surface water towards the skimmer on and off.
2. Because of the springtail issue I've also been running the filter overnight 24/7 for the past 2 days and that includes the SWG at 40%.
I wouldn't think that the FC would rise this much due to the constant running of the SWG but would it be due to this even if I haven't changed the 40% setting?
I'm also guessing the hose water entering the pool shouldnt cause the FC to rise that much or at all but thought I'd mention it just in case.
Thanks.
Thanks.
