So I’ve had my pool for a year now and never had a pool before.
I’ve had a couple of instances of cloudy water previously that I’ve needed to do a SLAM and got it looking good but I’ve come to realise there is a few things I’ve changed recently to help it be crystal clear.
1) I never actually scrubbed the pool walls ever in a year. I now scrub it once a week
2) in summer as my temps rose, Iwas only running pump for 6 hours, now I am 9 hours after needing to SLAM on the last bout of cloudy water. 6 hours was enough to turn over water once a day.
3) I have heavy leaf and pollen drop and would leave my pool cover for days without cleaning it up, so now I do it every two days or so.
4) I try and run my robot twice a week, from previously once a week.
I don’t know which point above has helped me the most to keep it looking crystal clear?
Previously I did noticed that always the entrance to the pool that the tiles were slippery, but didn’t think too much as the tiles were tiled on a curve. It was a post where I read that slippery tiles means algae is starting and to brush it ASAP. Since doing so the slipperyness is I think all gone. I must be honest and assumed that my robot maytronics m400 meant I didn’t have to hand scrub so I never did it until 3 weeks ago. I actually had two periods of cloudy water previously not long after each other and always maintained a CH of around 6ish as my baseline but one morning I woke and tested and CH was at zero!
So I’ve learnt my ways and I think I’m now on the right track with the new steps in taking.
here’s my question then. When I read about what levels CH should be, online a lot of resources say 2-3ppm. I know the TFP way and follow that but I wonder about the online methodology. I feel this is too close to 0, and it’s likely if you are not checking everyday at some point you will end up at 0 which isn’t good.
I know to use the cya to CH chart and do it religiously but why are a lot of resources saying 2-3ppm as it would be quite difficult to keep at this level without it ever hitting 0.
How long can a pool be at 0 CH and not have algae?
I find myself targeting around 6-8ppm now based on my CYA level so to avoid a SLAM, but sometime it can get to 9 or 10ppm
