Something to consider too is that adding LC does add salt. It's not a ton, but if you ad a LOT of LC, it could push your salt levels up to where you have to partially exchange anyhow.
Okay, I might be miss understanding youFC will eventually overtake whatever is in the water if you add enough of it.
The danger is we can't say how much that will be because we don't know what's in the water. Something is there that is consuming FC. It's also being consumed by the FC, but we don't know how much of it is there.
So - you can either follow the protocol for Ammonia (which is to keep adding 10 FC at a time and retesting, repeat until FC holds) or you can exchange the water out. I have to imagine that the costs for the water exchange might be less, depending on what it costs to fill the pool. If you do drain, I would do a No-Drain Water Exchange to avoid potentially shifting the liner. Here's info on that: Draining - Further Reading .
Which way to go depends on your cost of water and how lucky you feel. It could be the next 10ppm you put in finishes off what's in there and you hold chlorine fine. Or it could be dozens and dozens of chlorine jugs. Changing out the water is going to be more certain of a cost you can know, but will cost more than adding jugs if the next one would have been the last. Ultimately it's your call on which way to go.
Okay, I might be miss understanding you.
When you say keep adding 10FC, what does that mean. One gallon of 10% liquid chlorine?
Namco had 12.5% liquid chlorine. Would that be better?
Namco also had chlorine granules bag that were 80%. Is that better?
So I have been trying to raise my FC. I added 10 gallons of LC and it raised it from 0.5 to 1.5. So to get to 10 is going to take 90 gallons??? Or is it not a 1:1 ratio? LC will raise it faster once it hits a certain threshold?No, it means add sufficient liquid chlorine to bring your pool FC up to 10 ppm. Each 5.5 oz of 10% LC raises your FC 1 ppm. So to get from 0 FC to 10 you would add 55 oz or 3 cups 7 oz of LC.
You'd use less because it's stronger. You'd still be adding enough to bring you up to 10 ppm FC.
No!! Don't use that!! You'd be adding other additives that could affect your water!!
Just add enough FC to bring you up to 10 ppm, and keep it there. The more often you can test and add the quicker this part will go. Once you reach 10 ppm and it stays there, you can do a SLAM Process.
Yep, how much of a chemical you need to add to raise the PPM of that chemical in a pool is entirely dependent upon the volume of the pool.Gah! I guess that figure only works in my pool, a measley 4024 gallons. Funny, I didn't think that figure was dependent on volume of the pool...
I'm not a pool expert, but I just had this issue where I kept adding chlorine and measuring and my number never went up. I went through the 8 bottles I bought in the first 2 days and never saw the FC go up. So I went and bought another 16 bottles and kept dumping 2 bottles in and measuring 20 minutes later until it finally started to climb. I think my total amount poured in before the FC started to register was 16. No idea what was causing it, but whatever it was, the chlorine finally won the battle. Then it took 4 more bottles to get it to SLAM level and over night it only dropped 3ppm which means I'm still killing stuff, but at least there's a measurable FC level now. So just sharing my experience that I just had the same issue and eventually the chlorine did win.So I have been trying to raise my FC. I added 10 gallons of LC and it raised it from 0.5 to 1.5. So to get to 10 is going to take 90 gallons??? Or is it not a 1:1 ratio? LC will raise it faster once it hits a certain threshold?
Something is not right here. Do you have a cheap OTO drop test you can use? We don't normally recommend them because they only measure TC and only up to 5 ppm. But it would be useful to compare to the results of your FAS-DPD test. Maybe your powder is bad.
I have tried the color comparison test to check. It confirms the same low FC.
This is good to hear! I added another 10 gallons tonight. First 6 gallons and tested 30 minutes later. FC 1.5. Went out and came home and added another 4 gallons. Tested right after adding the chlorine and FC was 9! So the chlorine is good. I'll see what it is in the morning.I'm not a pool expert, but I just had this issue where I kept adding chlorine and measuring and my number never went up. I went through the 8 bottles I bought in the first 2 days and never saw the FC go up. So I went and bought another 16 bottles and kept dumping 2 bottles in and measuring 20 minutes later until it finally started to climb. I think my total amount poured in before the FC started to register was 16. No idea what was causing it, but whatever it was, the chlorine finally won the battle. Then it took 4 more bottles to get it to SLAM level and over night it only dropped 3ppm which means I'm still killing stuff, but at least there's a measurable FC level now. So just sharing my experience that I just had the same issue and eventually the chlorine did win.
Getting a reading is good! You may have consumed whatever was in the water eating up your FC.This is good to hear! I added another 10 gallons tonight. First 6 gallons and tested 30 minutes later. FC 1.5. Went out and came home and added another 4 gallons. Tested right after adding the chlorine and FC was 9! So the chlorine is good. I'll see what it is in the morning.
Back down to 0.5 this morning. Have added a total of 20 gallons. I guess I will buy 10 more and see what happens.Getting a reading is good! You may have consumed whatever was in the water eating up your FC.
So you likely had Ammonia, and now you have algae. Just follow the SLAM Process process from here out.Back down to 0.5 this morning. Have added a total of 20 gallons. I guess I will buy 10 more and see what happens.
45 gallons! Well thank you for that information. I will go buy 25 more gallons. The slam process says to not test more than once an hour.So you likely had Ammonia, and now you have algae. Just follow the SLAM Process process from here out.
I used 45 gallons for my slam, and I didn't have ammonia. You will get this!
No need to test more than once an hour. Test your FC. Use pool math to calculate how much to add to get back to your SLAM target.45 gallons! Well thank you for that information. I will go buy 25 more gallons. The slam process says to not test more than once an hour.
So how much chlorine should I add at a time and test how often. Also, I do this in the evening, right?
Basically, test, then add back to SLAM target. Your target with a CYA of 60 is 24ppm per the FC/CYA Chart. So if you test at 0ppm, you put 0 in Pool Math, put 24 for the target, put in the strength of the chlorine you're using, and it will tell you how much to add for your volume of pool. In an hour, if you test and it's 21ppm, you put 21ppm in the current, 24 for target, and it will tell you how much to add to get 3ppm more added. Repeat as often as you can, brush and vacuum often. Test and add at least 2-3 times a day, up to once an hour. The more you can do it the faster it will go. Taking a break to do things like sleep is fine - you'll just get back to it when you get up.45 gallons! Well thank you for that information. I will go buy 25 more gallons. The slam process says to not test more than once an hour.
Okay thank you. Off to the store, again...No need to test more than once an hour. Test your FC. Use pool math to calculate how much to add to get back to your SLAM target.
Do it all day long. If you can do every 1-2 hours, it will go faster.
