This is my first year using just 12.5% liquid CL and a FAS-DPD test kit, results are great. It has stayed crystal clear since opened in early June previously was always fighting algae or cloudiness.
FC 5-6ppm (6ppm target from poolmath)
CC 0
PH 7.4
CYA 50
Pool gets ~90% full sun it will loose 3-4ppm CL during the day. OCLT it looses 0 to 0.5. Zero bather load during the day, one or two ppl at night is it.
CYA at opening was zero. Raised to 30 then 50 which significantly reduced CL loss.
Is 3-4ppm daily loss expected or should I raise CYA further?
CC 0
PH 7.4
CYA 50
