35000 gallon pool
CYA: 50
PH: 7.6
Alkalinity: 90
Calcium Hardness: 300
Tested water around 1PM yesterday and had 5 FC (I use the powder FAS DPD test kit).
Decided to wait about an hour and add 2 quarts of 10% liquid chlorine to have FC at about 6 by 6PM (2 quarts would normally add about 1.5ppm).
Tested water at 6PM and FC was at 13. This means that the 2 quarts of liquid chlorine added somewhere between 8 and 10 ppm (assuming no "burn off" or a "burn off" of 2ppm).
I also had this happen one day last week, but thought it was a "one off" and decided to ignore.
Just wondering if there are sometimes quality control issues with liquid chlorine which result in a super strength liquid. Any other possible explanations?
CYA: 50
PH: 7.6
Alkalinity: 90
