Hi all,
Working on getting my daily/weekly process figured out after switching to LC, so I've been doing daily FC checks to watch the drop and figure out how much LC I need to add daily/every other day. My problem is the trend has changed from 4ppm a day to 1ppm a day drop. See trend below....
Is this typical? My CYA is 70 so my target is 8-10. My thought process was I'm waiting till I hit 9ppm, then add in 4 cups a day to bring it up 4ppm (per pool math). But that doesn't work if I loose a significant portion less than other days. The reason the FC was/is high right now is because when I switched to LC I brought it up to Shock level to see if Pool Math was accurate to my pool gallons for dosing with LC (it's pretty close!), but within the time in the chart, no FC was added.
Thanks for any insight!
--Dan
08/13/18 10:31 AM | 13 |
08/12/18 11:17 AM | 14.5 |
08/11/18 11:39 AM | 15 |
08/10/18 2:28 PM | 19.5 |
08/09/18 11:06 AM | 23 |
--Dan
