Hello, first time pool owner here. I touched on this in a different thread about a different issue, but I want to figure out a more detailed plan to deal with my Scale problem, and the Plaster Company's wishes.
My pool was filled at the start of 2021 (New Years Eve). The person that was hired to "Balance" my water didn't know what they were doing, and things like PH, TA, and everything else were MASSIVELY off the charts, all over the place, for 3 weeks (sometimes way too low, sometimes way too high). Finally he was fired by the Pool Builder, and I took over and had things balanced really fast, in a day or two, using TFP. Consequently , the pool developed a lot of scale during those first 3 weeks that won't come off with brushing.
The plaster company (not the plaster installers, but the actual plaster company, NFT POOL) want me to add ScaleTec to my pool, and see if it works, to get rid of the scale issues. In reading the ScaleTec instructions, it says it wants the FC to be lowered to 1.5 -2.0 FC, ideally, but certainly under 3. I called the ScaleTec company, and they told me that adding ScaleTec with FC over 3, is like adding water to the pool, since the ScaleTec will just get eaten up by the Chlorine, they said.
So obviously I don't want to do this during the Summer Time, due to CYA / FC chart and high sunny heat / UV levels, but I still want to make the Plaster Company (NPT Pool) happy, and my Pool Builder (who is clueless about water chemistry) says we have to do what the plaster company says (he's super stressed out.). So I'm kinda in a bit of a pickle. (and I'm also super upset about all this as well, the scale looks terrible).
That being said.... I was wondering if I waited to add ScaleTec in the Winter time when water is coldest as possible, would I have some lee-way with the FC levels & and potential algae growth? If I maintain my FC levels to say, between 2 and 3 in the winter time for say, 2 WEEKS, is there a chance that I won't get too much algae growth if the water is pretty cold (if so, how cold are we talking?). Is it best to not even consider doing this and just tell the Plaster Company NO?? Any thoughts, ideas / advice for how in the world I might successfully attempt to use ScaleTec with an FC level no higher than 3, I'm all ears.
In the meantime, after talking to ScaleTec company, I dumped in a bottle of their BeauTec , as they say Chlorine has zero effect on BeauTec. They said BeauTec might help with the Scale, but it will take much much longer than the ScaleTec. (Scaletec 2-4 weeks, BeauTec like 5-6 months or more.)
***as a side note, the person that failed for 3 weeks to "balance" my pool, was recommended to my pool builder directly by NFT POOL, since the pool builder said he wanted to "Cover His A**" with the water balancing. So that's another wrinkle. The plaster company is taking zero blame for how their recommended guy failed at water chemistry, so far.
