I have some newbie questions here, please bear with me....
- When I'm testing for CYA, should I look at the dot with one eye or two - and how far away should my head be from the container? I find I can see it for longer with one eye, and obviously when I'm closer to the container - so how should I be doing this?
- I've seen folks talk about diluting pool water with tap in order to test for high CYA levels - can you do the same to test for high levels of FC? For example, if I had a kit that could only test up to 5ppm could I dilute the pool sample by 50% and then double the scale?
I have the Taylor 2006 - so the second question is hypothethical, but still interesting to me!
Bic
Bic
