Hey guys I have a quick question. I posted a thread yesterday on replacing my water to lower CYA and I believe I did so. It was at roughly 100 and I believe I got it down to 60. Anyway, here’s my question.
I just begun the SLAM process. Just prior to testing I based my FC off of a CYA of 70( I figured I’d go higher just in case my reading was off. Prior to adding liquid chlorine my FC was 6. Using the calculator I added 7 Gallons of Liquid chlorine (10%). I figured I would shoot high once again and let the FC drift lower rather than not putting enough in.
Finally here is my question. I just tested post adding the chlorine and my FC level is 38.5. Wouldn’t this mean my CYA is actually lower than 70 or even 60. I think by adding 7 gallons of 10% with an FC of 6 to a 28K gallon pool wouldn’t raise it to 38.5?
