Hi,
New pool owner here. I've been lurking and learning for a bit. My wife and I have a 20k gallon fiberglass pool that has been open for a month now, learning about water chemistry, using drop tests, etc..
What I've noticed is a pattern of rapid rising PH, where I'm having to add a gallon or 1.5 gallon of 31.5% muriatic acid a week. Weather has been mostly sunny, not very much rain over the last month. PH seems to rise .3 per day on average. If I knock it down to 7.3 or 7.4, it will be back up to 8 in 3 days. I'll add 64 oz of acid, get it back down to 7.3 and repeat. Adding baking soda 3lb at a time to compensate for acid. I have tried playing with TA a bit to see if it has an effect on the rate of rise, it doesnt really. I tried TA of around 80 to 100 and it doesnt make a material difference.. I have been testing PH and Chlorine daily with TF pro kit. The other parameters weekly. I've done quite a bit of reading and searching on this, and was nearly resigned to it being normal for a SWG pool, but it still seems excessive. I noticed some SWG owners rarely add acid? I've looked into borates as an additional buffer, but I'm not sure if I want to go that route at this time.
Imagine Fiberglass pool, 20k gallons.
Pentair SWG
Cartridge filter
No water features.
Pump running 40 gpm full time.
heated at 84F.
PH = 7.8 (today) maintained between 7.3 to 7.8 (got to 8.1 while I was out of town for 3 days).
TA = 80 (today) maintained between 80-100.
FC = 2-3
CC = 0
CYA = 50
CH = 150
Salt = 4020
Water Temp = 84F
No borates.
For reference, Imagine pools requires me to log test results and maintaining their recommended values (below) for keeping the warranty valid.
PH 7.2-7.6
Total Alkalinity 80-120 ppm
Calcium Hardness CH 150-200ppm (for fiberglass, manual states to never add any)
Free Chlorine 1-2ppm - max 5ppm
Combined Chlorine - 0
CYA 30-50ppm
Pentair SWG
Cartridge filter
No water features.
heated at 84F.
FC = 2-3
CC = 0
CYA = 50
CH = 150
Salt = 4020
Water Temp = 84F
No borates.
PH 7.2-7.6
CYA 30-50ppm
