I would have thought that I would know and understand this concept by now having (successfully) owned a pool and used the TFP methods for 5 years, but my recent SLAM/OCLT efforts have led me to question how to use the FAS-DPD test with consistency. During my most recent OCLT attempt (last night), I did three FAS-DPD tests, all using the Speedstir, at both sunset and sunrise with the following values (CYA 60):
Sunset: 33.5, 31.0, 29.0
Sunrise: 24.5, 29.0, 27.5
From looking at old threads here, people have brought up different variables that could affect test consistency:
- Volume of water tested: this clearly affects results, but I have been pretty consistent to carefully use 10 ml.
- R-0871 bottle orientation and pace of drops: this is where I have not been consistent. I recently started to make sure I was holding the bottle vertically, but it is not clear how to do the drops, particularly when I have to do so many with each test. I have seen comments on not squeezing at all, but that doesn't seem to work even with a full bottle. Is there something magic about 1 drop/second? It is hard for me to be patient with that many drops! What are clear best practices for this?
- Amount of DPD powder used: I have been using a heaping scoop but have seen some posts that suggest using 2 full scoops.
- OCLT test level: does it matter if and how much I overshoot the SLAM level?
- Starting CYA: are there any different considerations when testing at FC levels of 30+?
