Hey guys, I have been using this site for years and had amazing results but I just opened my pool and the chlorine readings are perplexing me. Here is what happened:
I opened the pool yesterday. Ran the filter for about and hour and did my initial readings. PH was low, alk was fine, salt was low, Cyanuric acid was mid range, chlorine was at 2ppm (I opened the pool about a month ago for a problem and dumped in a few gal of bleach), and CC was at zero. I balanced the PH, added a bunch of salt, and threw in 6 gal of bleach (based on the app) to do a SLAM. SLAM level was 16ppm. I also put my salt water generator into shock mode so it will run constant for 24 hours. I do this yearly and it gives me crystal clear water for the summer.
This morning I do the chlorine test to see how much it dropped and the liquid didn't turn purple when adding the powder. So I throw out the water and tried again with the same results. So I tried the DPD chlorine test (the one that uses 5 drops and turns yellow) and the test turned RED! So the cheap test is saying the level is above 5 (that's as high as it goes) and the FAS test is saying there is no chlorine. Just for giggles I tried the combined chlorine test and it came back as zero. I checked the PH and it is balanced and salt is currently at 3150.
What am I missing here? Why is the FAS test not turning purple when I add the powder?
The tests are out of date BUT it worked fine yesterday so I cant say that's completely the problem.
