Hey everyone! I finally decided to replace my leaking Fanta Sea solar deck panels after some time.. For reference these are the ones -
www.poolsupplies.com
Now the issue.
I installed them two days ago and yesterday I actually felt hot water coming out of the return one back into the pool. Today I am feeling nothing coming out of it.. I am wondering if I am not receiving enough pressure to circulate through all 26 panels due to how this is set up. The first few hoses even have a little squish to them which I'd imagine they should be STIFF filled with water?
It's set up this way - return hose back to pool outlet from filter has a Tee attachment that the first solar panel is attached to for starting the circulation.. I can't imagine it can get the force? And the big mistake which I believe why I mention the pressure.. I just looked up Fanta Sea hoses and the 6' hoses from fanta sea only came up.. That's A LOT of sag to travel through for all 26 panels while sharing the pressure of the pool return pressure i believe? Here's a picture to show how the Tee is set up.
Thank you for any advise!!!
Grey 2x4' solar deck for your Fanta Sea™ Pool - PoolSupplies.com
Grey 2x4' solar deck for your Fanta Sea® Pool
Now the issue.
