I asked a family member to dump 3/4 of a gallon of 10% Chlorine in the pool this evening before they left, and they dumped almost all of a gallon of Pool Tech Algaecide into the pool. I had bought it while I was fighting an algae problem to do an experiment. I had collected some of it and put it in a cup with some algeacide to compare what happened as opposed to just chlorine.
The Algeacide us 4.98% Alkyl Dimethyl benzyl Ammonium Chloride. .02% Methyl benzyl Ammonium Chloride. 95% other. The pool is a little "soapy" and there's a little of that in the filter. It has cleared up some over the last couple hours. Is there anything I should worry about?
PH is high, about 7.8 right now, but otherwise everything else is about what it normally is. I'm being told they didn't add Chlorine, but my current FC level is 12.5.
I've been keeping my pool between 8/9 FC otherwise I'm getting some algea on the bottom. The smallest little bit, but I can see it. It doesn't grow, it doesn't change, it just settles at the bottom. On this note, I did slam the in July pool, and the water was clear, I was losing 0/.5 FC overnight. My CC was .2. Couple days go by, a tiny bit of algea when FC was at 4/5. I keep it at 8ish, no signs of it. I can't explain it, I just decided I can't SLAM the pool all summer (It was 9 days total, 5 consecutive days passed) so I would keep the levels a little high.
I had them run to the pool store for a sanity check, their printout is similar to my test, except phosphates from the pool store are 475. Should I be worried about phosphates? Limit on their sheet is 500.
Besides the bubbles, is there anything I should worry about? I have to assume the high PH is due to the high FC level of 12.5.
I appologize for the novel, but I wanted to give you all the information I have.
