New pool owner, ~6 months in. Live in Houston area, pool will stay uncovered all year, non heated.
Recently the water temperature has dropped to ~71F and the chlorine usage has seemingly almost stopped - need to know if this is normal and ok, and what else if anything I need to do.
FC - 6.27
TC - 6.67 (this is new, usually same as FC - ?)
pH - 7.6 (this is the level that the pool seems to seek, not much adjustment needed)
TA - 72 (seems to "seek" or go-to ~70, have tried to get it back to 80 recently, but doesn't want to go up...)
CH - 250 (have been raising slowly for awhile - hurricane Harvey took this way down, took quite a bit to get it back up)
CYA - 41
water temp 71F down from the 80s in the last month or so
So with the lower temperature my CSI is lower, more negative, ~.05ish to -0.18. Should I adjust my Target levels during the cooler weather? Or does this all look ok? Have had to add very little chlorine in the last week.
FC - 6.27
CYA - 41
