Hello, we purchased our pool last September, and this is our first summer with a pool. We are having trouble with maintaining levels.
Thank you for getting back to me. I purchased a kit from Amazon described as a Taylor K 1004, but when I received it the number on the box has E2095 Deluxe Pool Care DPD test kit. Not knowing anything about them, I didn't question it much. So maybe it is not that reliable?Total chlorine includes both free chlorine and combined chlorine (aka CC, aka chloramines). CC is created as free chlorine gets rid of (mostly) ammonia. The main source of ammonia is human secretions such as urine and sweat. It can also enter pools by use of some non-recommended chemicals. Full sun on the pool will usually break down the chloramines after a few hours of water circulation.
Have a read through those links I pasted above. Depending on your cost of water, you can also consider replacing the water and starting from scratch, which is sometimes a useful option. You'll benefit by doing your own testing with a drop-based test kit, such as described here:
Test Kits Compared
How do you sanitize if you don't shock? I triple shocked because we had small spots of algae on the floor of the pool and I wanted to stop it before it became a big problem.Welcome to TFP.
Follow the link posted above and you will ahead of the game in a few days. Knowledge is the key.
Test your own water.
You have to have a reason to add something to your pool. That reason is never "The pool store said to add......."
Take Shock for instant. Why are you adding? On my second year with my TFP and have never added Shock. With well maintained water chemistry its simply not needed.
Simple, I maintain my chlorine with a SWG at the upper range for my CYA. At that level my pool is always sanitized. Why should I add more chlorine (Shock) when its not needed? Algae is because chlorine levels are not being maintained. Weekly Shock treatment is like treating the symptoms instead of curing the problem through the "SLAM" process.How do you sanitize if you don't shock? I triple shocked because we had small spots of algae on the floor of the pool and I wanted to stop it before it became a big problem.
