Wouldn't it be fun to string together 20 cells in series to make the system work?
Probably additional side reactions that are favored with the plates losing some of the catalytic characteristics due to degradation.
I did notice as time went on, that current would degrade rapidly and cleaning what scale that was on the plates did not help much. However, I found that soaking the cell in an acid solution 8:1 would improve the cell conductivity and boost the current for a short period of time. But overall, it seems consistent with what you are describing.Once the ruthenium is gone, the titanium is exposed and it instantly anodizes in water to form a passive oxide coating. The oxide is still somewhat conductive but not nearly enough and so those area of the plate will simply produce hydrogen and oxygen by electrolysis of water. Chlorine gas formation will not be favored at all. One would expect more hydroxide formation in those areas which leads to high pH and calcium scale. Since the calcium scale will not adhere to the titanium oxide layer very well, it will spall off very easily. This is why you often see calcium snowflakes coming from returns as the SWG age.
I believe the side reactions may be much higher than what one might expect. If you run the numbers for a T-15 cell, the published and measured new cell production rates are almost half of the ideal calculated production rate based upon the cell current alone.At the anode, you will get mostly chlorine and maybe some oxygen.
Only after mixing, and for the CL case after UV exposure, is the PH neutral. Near the electrodes, I think there is the potential for very high and low PH.At the cathode, you get production of hydrogen that is directly proportional to the production of chlorine gas or oxygen gas.
The process should be pH neutral either way.
I have experienced cell scale even with a negative CSI for the main pool water. I believe this has to do with the higher PH near the cathode.The cathode is exposed to hydroxide as hydrogen gas is produced and this will produce high pH and possibly scale.
Given the flow near the electrodes is laminar and goes to zero at the plate wall, there may not be a lot of turbulent flow mixing going on within the cell so the ions produced at one electrode move toward the opposite electrode mostly due to ionic mobility which is a fairly slow process.
