Failed Jandy VS-FHP2.0
Dec 23, 2012
12
Appears the motor drive electronics in my VS-FHP have failed. The unit is 7 years old. Motor has power (confirmed), iAqualink shows Priming on my phone screen but rpm = 0. Using the iQPUMP01 to force the motor on doesn't change anything. When I removed the lid, the inside electronics were wet.
Question: Can I replace the motor drive with the newer model "R0688600, Gen II Variable Frequency Motor Drive" or do I have buy a whole new pump?
My unit is a circa 2013 unit, (part # R0534500) as shown in this link: Jandy VS Flo Pro Series Pump Parts
Don't think that control unit is available.
Shows you can replace your Gen I motor and drive with a Gen II motor and drive. It will save you a bit over an entire new pump.
Call inyopools and see what they say about just replacing the drive.
Is your pump on this list?
Product Description
Variable Frequency Drive Kit - R0688600
Compatible Pump List:
VS PlusHP VS
  • VSPHP270JEP
  • VSPHP270AUT
VS FloPro
  • VS-FHP2.0
  • VSFHP270JEP
  • VSFHP270AUT
ePump
  • VSSHP220AUT
  • VSSHP270AUT
@JamesW thoughts?
