Installed ten 12ft FAFCO solar panels on my roof in 2012 but experiencing pin hole leaks annually. Does anyone know what could be the cause of recurring pin hole leaks as one of the panels springs a leak 1-2 times per year requiring a $65 service call. FAFCO dealer says the number of leaks is normal!!
Have had only 2 panels leaking at the header area which required whole panel replace under warranty. Most of the leaks are fixed by plugging under warranty but since recurring (not on the same panel) and bothersome plus the $65 service charge. My roof solar system is running 12 months of the year for 6-8 hr per day and drains down when pool pump turns off at the end of the day. Water chemistry is well within range as I sample myself. Also panels water flow controlled by pentair solar controller and I run the pool at 87F year round. The leaks generally occur in Mar April or Nov each year
