So I am a long time TFP'er. I had an above ground 15,000 gallon pool for years and maintenance was a breeze. It consumed about 2ppm chlorine a day which I add via 12.5% liquid chlorine. Fast-forward to today and I have moved to a house with a 30,000 gallon in-ground vinyl pool. The pool regularly consumes 5+ ppm of chlorine daily and seems extremely susceptible to algae in spite of maintained chlorine levels. I have gone through several SLAMs, they always go on much longer than I would expect and never really make a dent in the chlorine demand. My gut says I've never really completely wiped out whatever nasties are living in the pool.
So I've currently been SLAMing since 7/11 and have yet to pass the OCLT. Current numbers (taken with TF-100):
FC: 16
CC: 1
PH: 7.2 (before starting SLAM)
TA: 180
CYA: 40
CH: 440 (it has admittedly been a while since I tested this one and I suspect it is lower now)
And my recent OCLT results:
7/15 lost 3 ppm
7/16 lost 3 ppm
7/17 lost 2.5 ppm
7/18 lost 1.5 ppm
7/19 lost 2.5 ppm
It is discouraging because I feel like I'm not making any progress. I thoroughly brush every surface daily. I've removed the light and scrubbed the niche. I've scrubbed under the ladder and inside the skimmers. I've opened up and hosed out my DE filter. I've even taken a toothbrush and scrubbed around the seams where the steps meet the liner. The last few nights I've vacuumed, skimmed, and emptied my skimmer and pump baskets right before bed to eliminate any debris from interfering. Pump has been running 24/7. My reagents are fresh. The water has been clear and sparkling since 7/14.
So what is the deal? Does this seem excessive or am I just getting impatient? I am using about 3 gallons of 12.5% liquid chlorine a day.
I know the previous owner didn't maintain the pool very well (it was bright green in the listing pictures!). My fear is that there is some biofilm or something hiding in the plumbing that the chlorine can't fully break down.
FC: 16
CC: 1
TA: 180
CYA: 40
7/15 lost 3 ppm
7/16 lost 3 ppm
7/17 lost 2.5 ppm
7/18 lost 1.5 ppm
7/19 lost 2.5 ppm
