Exposed rebar in spa question
JC707
392
Bay Area, CA
Jandy Aquapure 1400
Morning folks. I noticed a small piece of rebar showing thru Gunite in the spa right where jet plumbing run is.
Should I ask builder to cut this out or cover with hydraulic cement before pebble is sprayed in?
Sorry for the bad photo I will take a better one once back from work.
Thanks!
That needs covered up with additional material before plaster. The rebar may rust and bleed thru the plaster constantly staining it otherwise.
Reactions: JC707
