Going the BYOP route through local Austin branch. I intend on updating this thread every step of the way with plenty of pictures. Any/all feedback is appreciated!
Current All-In Cost: $67,000 (Quoted 77k-82k by big builders for same specs and inferior equipment)
I have already changed depth from 4-5-4 to 3'6"-5-4. So we will lose the bottom step at entry point. Also equipment pad will be on side of house opposite master bedroom.
We are a family of four with kids ages 6 and 7. Activity type pool desired. We will have a portable basketball hoop, portable SRS Smith slide, and possible volleyball net if I can figure a way to get the raised beam side right.
POOL DETAILS
1.) Pool Area: 500 sq. ft.
2.) Pool Perimeter: 100 ft.
3.) Pool Gallons: 15,000* (est.)
4.) Pool Size: 15 x 30 (water)
5.) Pool Shell: Gunite
6.) Ledge Size: 5 x 10 (water)
7.) Water Depth(s): 3'6"’ x 5’ x 4’
8.) Ledge Depth (Water): 10”
9.) Plaster: CL Industries: Majestic Isle
10.) Coping: Gray Leuder Stone (12”)
11.) Decking: Brushed concrete with Gray Kool Deck Coating
12.) New Deck Area: 530 sq ft
13.) Exis. Deck Area to be Covered: 210 sq ft
14.) Raised Beam: 18” x 32’
15) Beam Face: Chopped White/Cream Leuderstone
16.) 2 Skimmers / 4 Returns
WATER / OTHER FEATURES
1.) LED Bubblers: (1) at Ledge
2.) Sheer Descents: (3) at Raised Beam
3.) Umbrella Sleeve: (1) at Ledge center, (2) in deck on each side of pool
4.) Auto Fill: Add’l plumb. req’d
POOL EQUIPMENT
1.) Pump: Pentair Intelliflow Variable Speed Pump
2.) Filter: Pentair Clean & Clear 520 Cartridge
3.) Heater/Chiller: Pentair UltraTemp 4120 H/C
4.) Cleaner: Pentair (Robot) Prowler 920
5.) Control Box: Pentair EasyTouch P4
6.) Remotes: Screen Logic Bundle (adapter & wireless kit)
7.) Sanitizers: In-Line Chlor (It will only be used on vacations, I will be adding liquid by hand using TFP method)
8.) Pool Lights: (2) Pentair IntelliBrite 5g Color LED 12v
POOL DETAILS
POOL EQUIPMENT
