- May 6, 2022
- 2
- Plaster
- Jandy Truclear / Ei
I've read through multiple threads stating to check this or that when it comes to the error on the power pack that reads "Check Cell". So, I have done the following:
The pool was built and completed in May 2018, and it's 16,350 gallons. The model number of the salt cell is TRUCLEAR11K, and the model on the power cell is TRUCLEAR35P. I have read that these cells need replacement every now and then, but it's unclear to me WHY it would need to be replaced every 3-4 years. Why do they not last much longer than this?
I have sent an email contact to Jandy for support, but in the meantime while I wait for their (hopeful) prompt response, does anyone else have any other suggestions for me or tips?
Thank you in advance!!
1. Clean the cell of any and all salt buildup. It's clean as a whistle.
2. Check the water temperature - Has been in the mid-80's for nearly 2-weeks now.
3. Check the salt level - Salt level reads between 3200 - 3400 steadily for five days in a row.
4. Yes, the salt cell does leak a little, but it always has since the pool was installed. I thought this was normal :/
