- Mar 15, 2014
- 65
- Vinyl
- Hayward Aqua Rite (T-15)
I've got a problem similar to many other posts, but somehow not finding the answer, or not understanding.
My Aqua Rite SWG with T Cell-15 has started giving erratic readings that jump around but mostly; salt around 1300, and 0 instant salinity (I've not tested the salt level, but it's been fine all summer, no reason to believe it's suddenly dropped); voltage 30+ and no amps, not producing chlorine; temp seems to be correct 87-90; and desired output seems to be correct and changes when I move the dial.
The readout keeps jumping to metric, I'll reset it, and the next time I check it's back to metric. Sometimes I hear a faint click, the lights flash, and it will give "normal" numbers for a minute or so, acts like it's producing chlorine, but then goes whacky again.
System is 10 years old, I replaced the cell in 2014, and replaced the thermistor around that same time but can't remember when.
So is my cell bad, or is it a problem with the board?
