Hi all! I had something seemingly bizzare happen last evening, and wanted to see if folks have any advice. I cleaned and reinstalled my filter cartridge (as I have done periodically in the past), and then turned the pump back on. About 10-15 minutes later noticed that the pool level had dropped about 5 inches. I have a 16'x32' pool, so I imagine this was hundreds of gallons of water that left the pool and went somewhere. There is no visible surface water or wet soil anywhere around the pool, and no visible leak at the pump and filter.
I immediately removed and re-inserted the filter cartidge, sealed the filter, and ran the pump for another hour, during which time the water level fell about one more centimeter. I turned the pump off at that point (it's been off ever since), and called it a day. Waking up this morning, the water level had dopped another 3/4 inch, and now sits just below the skimmer intake level (picture attached). However, there has been no perveivable further water loss all day today (I marked the water level at the pool and inside the skimmer well with tape this morning).
I've kept the pump off since last night, and have been trying to narrow down what caused this. I don't see any obvious water movement such as water entering back through the return jets. At this point, the only possibilities that come to my mind are (1) A leak on the suction side, but my skimmer still has water inside it and it's water level has not moved down all day today, and a leak should not have caused 5 inches of water loss in 10-15 mins, or (2) something else in my system which caused the water to exit my home and into the main sewer when I ran the pump (still doesn't explain the overnight water loss after pump was off).
I bought the home about a year ago, and am attaching a few pictures of my pool setup, to see if folks think there is something that I may be unaware of in my pool setup which could be at play here. Thanks in advance!
