I had my pool installed and up and running last spring, and have had an ongoing problem with the pump since. Anytime the pump is running at low RPM the SVRS kicks, and shuts off the pump. It used to happen only at 1500 RPM and below, and then it was 1600, then 1700. Now the only way I can keep the pump running is to program it to maintain 1800 RPM or higher.
There doesn’t seem to be a suction side air leak, and I really don’t know what else to troubleshoot. Anyone have any suggestions? I’ll attach some photos of the equipment pad.
Thanks!
Thanks!
