I have a 33000 gallon gunite pool. Earlier this year, I did a 3/4 refill. I corrected the PH and alkalinity with numerous gallons of acid. My CYA is 31 and the water itself is perfectly clear at this time. My issue is that there are several sections with algae on the walls and bottom. No amount of scrubbing with a metal brush will remove it. For this reason, I don't feel it is yellow algae. I have SLAMed the pool 3 different times with hours of scrubbing the affected areas to no avail. I have kept the CA well above the SLAM level for days on end. Again the water is perfectly clear but the walls never become algae free. Extremely frustrating. Any help would be appreciated.
