I am doing a pool renovation and am updating the electrical box
I am going to remove the two timers in my box - don't really use them for anything. The new pump I got is a black and decker and has a controller attached to it. Don't really see the need for the timers in here.... thoughts?
I have 30 amps going in to the box. Old config was a 20 amp dual pole breaker supplying the pump and the LP heater, which seemed to work fine. There was another 20 amp breaker that supplied a receptacle on the side on the electrical box (a GFCI), then the pool lights.
I am adding a SWG and outlet at a gazebo to the mix, wondering if anyone has thoughts?
I was thinking 20 amp dual pole (240V) runs the Pump and SWG. My pump claims 8 amps (Black and Decker 2hp - BDXBTVAR200). My SWG is a Hayward W3AQR15, I can't really figure out how many amps it draws but I saw somewhere around 8amps. So 8+8 = 16, still have the 20% buffer on that breaker.
I was also going to leave the pool lights on the GFCI outlet (obviously the lights need a GFCI). The lights are LED and are very low, I think less than an amp each (have two)
Then the only things left are the LP heater (presume a very low draw) and the outlet at the gazebo. Don't see any super high draw items on that - possibly a TV/ceiling fan/LED lights. Both the heater and gazebo outlet are 12 gauge wire. Any real advantage to using a separate breaker for both of these? My initial thought was add a new GFCI breaker and putting the heater and gazebo on it.
Also, thoughts on GFCI breakers vs first outlet?
Replace 20 amp dual pole for pump and SWG with a GFCI version?
Thanks!
Thanks!
