Everything will get fixed and you will enjoy your pool. This will be a memory. (Hey remember the time we had the whole power co. come out and visit our pool, you'll say as you're sipping a cool one in the lounger.) :-D
AimeeH said:I can't thank everyone enough for all of the information. It has educated me enough to confront my PB about the bonding to which his reply was that county code did not require rebar under my cement (if I recall correctly).
Excerpt from http://www.lex-co.com/Departments/CommunityDevelopment/BuildingPermitsFAQ.html
Q: Is any work exempt from building permitting?
A: The following items do not require a building permit:
Ordinary repairs and maintenance
Fences
Retaining walls unless supporting a surcharge
Water tanks
Sidewalks, driveways and patios
Painting, papering, tiling, carpeting, cabinets and similar cosmetic finish type work
Swimming pools accessory to a one or two family dwelling
Swings and other playground equipment accessory to a one or two family dwelling
One-story detached storage structures accessory to a one or two family dwelling, provided that the floor area does not exceed 500 square feet
Shade cloth structures constructed for nursery or agricultural purposes and not including service systems
Window awnings supported by an exterior wall
Movable cases, counters and partitions not over 5 feet 9 inches in height
AimeeH said:Ohm-boy.......not Lexington Co. Richland Co. A permit was filed and there was a bonding inspection before the concrete decking was poured.
kevreh said:So does the whole deck have to be removed to do the bonding, or could something like a 1" strip of concrete be cut out every 10' then rebar and new concrete get filled in? Asked another way, how oftent does the rebar have to be placed to dissipate voltage between the pool and deck?
