I woke up to my waterfall frozen and a sheet of ice on my pools surface. My water level decreased about 2 inches. Following advice from TX Splash, I refilled my pool and used pool noodles to keep the skimmer doors open as well as prevent ice from forming in the skimmer.
Well I went to work for about an hour and received a phone call from my wife panicking. Water was spraying from the elbow leading out of my pool pump. I instructed her to turn off the pump and drove home as quickly as I could.
I have attached a few pictures. The water is leaking from right about the 2” marking in the elbow. I’m assuming the pipe started getting warm and the pvc glue started melting.
The elbow is not cracked. One side of the connecting pipe has just started to separate. I’m not sure what caused my pool pump to run hot. The pool pump basket has melted.
I know I need to replace the basket and fix the pvc. Any ideas as to what caused the basket to melt?
The high today is 35 but our low is 20. Should I attempt to fix the pvc? Or drain the pump and filter? Can I use a heat gun to melt the pvc glue or does the pipe need to be cut?
Thanks
Thanks
