What should I use to calculate the increase of FC when adding liquid chlorine? Bleach?
how do i get that? was looking to buy the chlorine in bulk at a pool store.Yes with the appropriate % strength of what you are using.
Thanks. Assuming any Liquid chlorine bought at a pool store is either 10% or 12%? or does it even matter?You need to know your current FC and your projected FC target as noted on the FC/CYA Levels. Once you know that, then the PoolMath APP's Effects of Adding can tell you the effect of adding X-Amount of 10% chlorine to water. In my signature is a link to the older web version which is another method to determine dosage amounts.
Those are the most common strengths. Once you confirm which one you have, you can modify the chlorine strength in the APP or web calculator versions for accurate dosing.Liquid chlorine bought at a pool store is either 10% or 12%? or does it even matter?
They can tell you if buying bulk.how do i get that? was looking to buy the chlorine in bulk at a pool store.
thank you. Do I apply the strength under the bleach option? and input the strength in the 'bleach percentage'?Those are the most common strengths. Once you confirm which one you have, you can modify the chlorine strength in the APP or web calculator versions for accurate dosing.
Yes, then an amount.Do I apply the strength under the bleach option? and input the strength in the 'bleach percentage'?
