HiHey Fish,
If Pool clown and Joyfulnoise's instructions don't help, use an multimeter in continuity mode to verify the wiring from the outdoor board to the transceiver card is good, or temporarily re-connect it with a known-good short length of cable. If the problem persists, the transceiver or the outdoor board could have bad comms.
Give us a little more detail...
1. do you have an intelliflo pump - or anything else connected to the comm port we can use to verify the outdoor board's comms?
2. what is the FCC:ID on the back of your handheld remote (P4HEASYTOUCH or P4HEASYTOUCH2A)? (the transceiver cards are different)
3. do you see any activity on the transceiver card 485 or RF leds? the 485 led blinks when it talks via the comm port, the RF led blinks when it receives a command from the remote (it can't if it's not paired). if your card's fcc:id ends in 2A and both leds blink in repeating a pattern (5 blinks, pause, repeat) then the card is dead.
Can you tell anything from this video? Pool clown and Joyfulnoise's instructions did not work
module_5422_low1.mov
