Easytouch and Spa-Side Remote problems
TBan
1
Huntington Beach, CA
Anyone ever come across this issue, where the Easytouch system (PS4 in my case) intermittently turns the Spa-Side feature off by itself?
I have a DIY circuit designed with optocouplers connected to the is4 terminals, with a wireless receiver momentarily triggering the is4 ground terminal to one of the is4 control terminals when a signal is received. When I initially turn on the Spa-Side Remote feature, it all works perfectly. But after some random period of time (sometimes several hours, sometimes just a few minutes), it stops working due to the Spa-Side Remote option switching Off in the Easytouch menu. If I turn the feature back on at the ET panel, everything is fine again until it turns itself back off.
Here's a rough diagram of the circuit
It's a pretty simple design. I used optocouplers to keep the is4 terminals isolated from the ESP32 controller's power circuit. All 4 channels work as expected when the Spa-Side remote function is turned on, I just can't seem to keep it from switching itself off after a period of time.
Moved from here.. Easytouch Intermittently Turns The Spa-Side Remote Feature Off -- DIY Controller Build
Yes. same issue here. Just noticed it in the last couple months. May have started up to 6 months ago. I just updated brick to 5.2 build 738 Rel. 2 days ago to attempt a fix. Did not fix it. It may have followed power outage? or when I turned breaker off to replace equip parts? or when main panel was turned off for solar panel installation? All these happened in last several months. I will try flipping breaker and see if it helps and report back. Could the reoccurrence of your issue have followed an outage?
Reporting back -> did not fix it
@TBan
Most spa side remote problems are due to intermittently bad spa side remotes. They get corroded inside which often makes them intermittently turn things on or off.
When I moved your post from an old thread, it may have caused us some confusion about your specific problem. How about telling us again about the problem you are having.
Jim R.
