Easy touch scheduling
GmoneyG
10
Ottawa, Ontario
Pentair Intellichlor IC-40
Hello,
My AUX 3 doesnt appear to be working and im not sure why. Wondering if anyone has some thoughts?
Pool - on 24/7 @ 36GPM
LOW SPEED (AUX 3) - 7PM-12PM @ 20 GPM
The ET clearly shows AUX 3 is on, yet Status under Pump shows it running at 36 GPM. I've double checked my clock and its correct.
Thanks
The programming of the system always runs the higher speed or GPM that is established.
Since your Schedule is for POOL at 24/7 at 3600 GPM, it will always run this speed or if a program has a HIGHER GPM it will run that.
Try this. put the 24/7 schedule at 20 GPM and put AUX3 at 36 GPM.
It will then ramp up once that scheduled time starts.
G,
The Pool circuit must be the slowest speed you ever want to run.. Then you use additional circuits to increase the speeds.
And.. if your pump is running, you should be making chlorine, otherwise, what is the point???
