I am in the process of wiring my Easy Touch panel/load center and have some questions regarding the wiring. I was planning on mounting the panel outside on my rear garage wall next to where the pool equipment will be installed. I want to run 8-3 from a 40 amp breaker in the main panel to a 2 pole 40 amp gfci breaker next to the Easy Touch Panel and then from there 8-3 to the Easy Touch panel. If I wire it this way am I able to skip the gfci breakers for the pump, lights, etc in the Easy Touch panel? Just trying to save a couple of dollars if I can. TIA!
