I'll acknowledge right off the bat the real solution to this is probably to rebuild the plumbing. That said, I'd love it there was an easier, if not permanent solution to this:
Upon starting my pool for the season I discovered a small, but significant leak in one of the joints in a fitting in the line that runs from the pump to the sand filter. The leak occurs where the PVC pipe is glued into the female side of a union. See attached photo. I've temporarily stoppped it with rescue tape (great stuff, by the way) but I don't expect that to last long.
I've had good luck on the suction side patching these leaks with 2-part epoxy putty. But I'm not sure it's going to work on the pressure side. Suggestions?
IF I have to replace the line, is is possible to do this with a single piece of flexible pipe rather than the usual rigid pipe and multiple 90s?
