- Aug 31, 2021
- 215
- Plaster
- Pureline Crystal Pure 60,000
I've recently noticed that my Calimar 3hp VSP occasionally shuts down on undervoltage, throwing an E-08 error - but only under the following very specific conditions:
I've checked all wiring connections and they're fine, voltage to pump is normal. The pump shares a 240v breaker with the heater and with a Polaris booster pump (not ideal, I realize, but it was like this when I bought the house and my main panel is nearly maxed out). The air blower is on a separate 240v breaker that is shared with the waterfalls pump. iAqualink system, lights, and SWG are on a separate 120v breaker.
Anything else I can check? Is it likely my pump drive or aftermarket automation control panel (basically equivalent to the Calimar CMARVSPIB) is defective?
The obvious workaround is to not use high speed unless really necessary. I might also try reducing the high speed rpm slightly and see if the issue persists. But I'd like to understand the root cause if possible.
- High speed (set at 3450 rpm) is selected while running the spa, with air blower on
- High speed is selected immediately after switching the pool back from spa mode to pool mode after running in spa mode for awhile
- Running the pump at high speed during pool mode (I run high speed for 15 minutes first thing every morning to ensure good priming)
- Running the pump at high speed in spa mode with the air blower off
- Running the pump at medium speed in spa mode with or without the blower on
