- May 20, 2017
- 27
- Plaster
- Hayward Aqua Rite (T-15)
I have the pictured dual speed pump pool panel. Primary timer is mechanical with high speed secondary timer as a DIP switch. Also has two slide switches for Manual-Off-Auto for both High and Low speeds. The High speed slide switch is very touchy-- if not set just right, the pump will cycle on and off multiple times a second which I presume is not good for the pump. I've thought about bypassing the switches with toggle or rocker switches, but they are soldered onto the PCB. I can't seem to find this panel when searching the internet. Anyone know what it is?
Is there a better panel to control the pump?
I also have a SWG that is not wired in correctly-- it has power whenever the filter pump breaker is on and I have not figured out from this wiring diagram where I should tap in 240V power to only come on when the pump does per recommendation in the SWG section. Should it come on with either Low or Hi speed? I've been keeping the pump on about 6 hrs high speed and low speed the remaining 18 hrs (ie, slider Low to Manual, slider High to Auto) and set the SWG to 30%.
Thanks!
-- Glenn
Thanks!
-- Glenn
