- May 18, 2015
- 356
- Plaster
- CircuPool RJ-60 Plus
I have an old 1.5 HP single speed 240 vac Hayward super pump.
Is there a variable speed pump that is a drop in replacement as far as size and positioning of the inlet/outlet fittings?
I’d like to replace my pump but not have to re-plumb. The inlet would be the biggest concern. No room there on the existing plumbing to modify. The discharge side however I could re-plumb if necessary but I’d rather not.
Is there just a motor upgrade I could do also? Keep the pump housing and just retrofit the single speed motor to a VS?
