Hi! This is probably a beginners question so my apologies. I need to reduce the water level in my attached spa to access the jets to change them. I'm attaching photos of my plumbing. Do I just switch the drain from pool to spa mode, but not switch the returns? So it displaces the spa water to the pool?
BONUS QUESTION:
Is there a way to run the spa jets AND pool returns? Will having the valve pointed in the middle do that? When it gets below freezing, it would be ideal to have water running through both. Thank you!
BONUS QUESTION:
