Hey all, so it's been 4 years since my pool was constructed and despite my best efforts to try to control the CH levels through an at home water softener and pool chemistry, the levels just kept rising and rising year after year. I'm probably close to or over 1k CH by now, and I can see little calcium flakes floating in the water. What a bummer. Curse Arizona and your hard water and super hot climate!
So anyways, I've been looking into ways to fix this by replacing the water. Osmosis companies wanted at least 800+ dollars to come work on my 20k+ gallon pool. Too much! I read up on here about using a sump pump to drain the deep end while filling the shallow end with hose water. I think I'm going to try this technique! My only problem is my sewer clean out is in the very front of the house, probably a good 100+ feet away from my pool.
-______-
So I have no good drain out options nearby. Normally I've been backwashing my sandfilter into a 12x 50 ft side space next to my home and it's been no issue. But to drain huge percentages of water I think I'll need to get to an actual drain.
I've heard that instead of using the sewer clean out, I could use a sink or bathtub inside the house. Does this sound reasonable to you guys? My kitchen sink is only about 25-30 feet away from the pool.
I'm about to purchase:
and this hose, since it looks very light for me to carry, being the weakling that I am:
Thoughts, concerns? Anything else I should buy or try?
-______-
https://www.amazon.com/gp/product/B000X07GQS/ref=crt_ewc_title_dp_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Amazon.com : 75 ft Garden Hose - Upgraded Expandable Water Hose Kit with 3/4 Solid Brass Connectors Fittings, Valve, 8 Pattern Spray Nozzle, Durable Latex Core - New Expanding Flexible Gardening Hose : Garden & Outdoor
www.amazon.com
