So our pool was full of algae again. It gets away from us every time the weather starts to change. The steps were badly cracked and a chunk of the plaster was cracking and about to fall off the wall. We heavily chlorinated the pool for a couple of days and then drained it completely. Rusty repaired the steps and wall, then rinsed/scrubbed the walls with water and bleach. We then started refilling with tap water. He also emptied the sand filter and refilled with new sand. The pool is almost full now. We decided to do all of the tests and here are the results:
FC 0.5
CC 0.5
TC 1
CH 350
TA 110
CYA nonexistent... he filled the tube completely and the dot was still completely visible
So what is the next step in this process to get the water chemistry balanced?
FC 0.5
CC 0.5
TC 1
CH 350
TA 110
