Hey everyone, I’m a newbie here and recently ran into an issue on my Hot Spring. We took a trip and when I came back I noticed almost all the water was gone. I tried to troubleshoot but it kicked into protection mode even after I refilled it. Left it off overnight, it held water, and it fired up the next day only to find that water was rushing out from behind the access panel. After googling a bit, it appears the drain fitting on the pump sheared off. Pictures below.
I have 2 questions... first, will I need to replace the entire wet side or is there a tip/trick to back the broken fitting out so that I can fix it? Or should I just call a service company?
Second, we have freezing temps here and I am worried about more damage while I get it fixed. Anything I should do besides drain it all the way via the drain plug? I am worried about potential residual water hanging around in other parts of the hot tub.
Thanks in advance for any advice!
