I feel sure this question has been answered, but I've searched and read many posts and not found one that quite matches what I'm seeing. My DPD test turns pink then goes to a color I'd call taupe or brown but never clear. I am definitely using the right reagents, and they don't show the color changes that would indicate they've gone bad. I have tried using an extra scoop of R-0870 with the same results. I wonder if I can't add R-0871 fast enough and whether a speed stirrer would solve the problem, but if that's not likely the issue, I'd rather not make the purchase. This is a new problem. I was previously able to get to clear.
Pool status details: My pool has terribly high CYA. I estimated at 270ish by diluting. When I took over pool care for our family, I discontinued di- and tri-chlor and have been adding gallons and gallons of liquid chlorine, overshooting what the pool calculator recommends since it hasn't raised FC as much as predicted. (My pool size estimate and/or CYA estimate may be off.) Because we want to have the pool resurfaced within the next year and we can get a one time break on the water cost, I'm trying to manage it at high CYA and take advantage of the rainy season (18" per month over the summer) to drain a few inches after each rain and let the rain refill. I've taken out about a foot this way so far. I need to keep the FC really high to keep the algae away, which I am not doing very effectively. Sadly, my Dolphin also just died in a lightning storm along with three other expensive items, contributing to my frustration about spending so much money and effort on the pool just now.
FC: That is the question! OTO is bright yellow, not orange or brown. DPD is a mystery as it never goes clear.
CC: I added the last of the MPS we had on hand, so I couldn't test just now even if the DPD test were cooperating. I have often gotten readings around 4. (Only one box of four MPS packs was ever bought for this pool, not a regular or continuing treatment.)
pH: 6.8 (has come down after rain, raising again with Borax)
TA: 70
CH: 275
CYA: 270ish
So, do I buy a speed stirrer? Is another issue more likely the explanation? Thanks in advance! The help and encouragement of people on this site are so appreciated!
TA: 70
CH: 275
CYA: 270ish
