The first half of my season was near perfection with crystal clear water and no chemistry issues. I’m not sure if the city flushed the water system but for the past two months I’ve been battling iron in the water. My pH keeps creeping up And alk keeps creeping down. CC has NEVER been above .2ppm and never had algae, thanks to TFP. Iron keeps settling to the bottom no matter what I do. In South MS and we haven’t had rain in almost two weeks so I’m forced to fill with more city water. I e blocked the aerator on my intex return so it keeps pH somewhat in check but it still goes up. I only add borax, bleach, non-metal chlorine tabs, dry acid, baking soda to balance. I’ve tried the poly fill bucket, in the skimmer, DE in the filter, sequestrant but all to no avail. Vacuum to waste works for a little bit but again I have to refill with city water.
What can I do that will work besides having water trucked in? It’s late enough in the season that it’s not an option. I’m to the point of desperation. My husband got back from deployment a month ago and has only been in the pool twice because I can’t keep the metal from precipitating. Does the culator actually work? And why would my alk and pH keep being crazy? I know low alk can cause pH to go nuts but nothing I do keeps them in check. First two months I had no issues whatsoever until the metal showed up. Now it’s planet of the apes and I can’t keep it clean and balanced. Would iron do that?
