Dolphin S300I vs Dolphin M500
trmiv
Active member
Jun 6, 2016
43
Wake Forest, NC
#41
lol that's funny we have a Roomba as well and it goes off at 2:30 every day.
Now if I could just get a robot to clean up the dog poop from the dog yard I'd be in business
BTW in looking for a caddy for the S200, I found an ebay listing from poolsuppliessuperstore for the caddy for $99. Appears though that poolsuppliessuperstore is the same exact company as Doheny. It's odd though on the Doheny site when I find the caddy here: Dolphin Robotic Cleaner Parts | Doheny's Pool Supplies Fast and then add it to my cart, the picture that shows up in the cart is totally different than the one on that page.
darin.brown
176
DFW, TX
#46
getting ready to have electrical run tomorrow and had planned on picking up the s300 for my cleaner. I've got a pair of power outlets on the outside brick, about 20' from our waterline. I don't want to mess with another extension cord so would ideally plug the s300 into an outlet, set it on the deck and let it do its thing but I think the 20' may be too far away? I could have the electrician install a power outlet near one of the posts on our patio hopefully which would place it about 7-10' from the waterline.
the pool itself is 33x25 and the existing power outlets attached to the houe are roughly at either end of the pool so the 60' cord should be able to reach. Another part of the equation is that one of existing power outlets may be behind our spa and the other behind our grill. there is another outlet outside the back door that might work as well as it's about 20' from waterline and would come in around the mid-way part of the pool. perhaps that's my best option yet since I could just keep the cleaner stored there under cover and just wheel it out 5-6 feet or however long the cord is on the caddy/power supply
Geebot
694
#47
I'm not entirely sure why they don't advise using an extension cord (other than it creating a point of entry for water in case of a surprise shower). The power cord is itself a modified computer power cord (a three-prong extension itself, modified to lock in place).
darin.brown
176
DFW, TX
#48
yeah, I'm guessing it's just to cover themselves from another potential point of water entry but I gather most cases involve running their power cord to an extension cord and then back to an outlet. I was just hoping to avoid having to do that out of pure laziness on my part :)
with the supplied cord being 60' I think I might be okay using the outlet by the back door and under the covered patio. if the electrician will install a new outlet at a patio post for a nominal fee it'll be worth having it available to use down the road but I'm hoping the current outlets will let me use the cleaner without having to mess with another extension cord.
Road scholar
Active member
May 11, 2014
41
Bowie, Maryland
#49
I have one of those heavy duty weather resistant extension cords that has a spike on the bottom. It's the ones they sell around the holidays targeted at outdoor lights and blow up frosty the snowman lawn ornaments. I keep it plugged into an GFIC outlet near the pool and pull it out when I use the bot. Simple.
Jun 1, 2013
29
#50
I was going to buy a dolphin triton plus - ended up buying the M500. Spent a little more than I wanted, but like the 3 yr bumper to bumper warranty.
Do you guys leave the pool covered with the bot is running?
What about the pool pump, do you leave the pump running?
New to this robot life style - any suggestions?
smiticans
Active member
May 27, 2016
34
New Jersey
#51
I've never owned a Dolphin, just Aquabots and the Polaris 9550, so I can't speak for other Dolphin owners.
"Do you guys leave the pool covered with the bot is running?"- Assuming you're talking about a solar cover, I would leave it off the pool unless the M500 has a floor only option. Otherwise the dolphin could get stuck on the cover when it climbs the walls.
What about the pool pump, do you leave the pump running?"- Doesn't matter
New to this robot life style - any suggestions?"- ;
  • Remove the cleaner from the pool after the cleaning cycle is complete, and store it in a shed or somewhere it won't sit in the sun all day.
  • clean the canister after each cycle
  • Do not turn it on outside of the pool water,
  • During the winter, store the cleaner inside or in a heated area.
Those are the only suggestions I can think of at the moment.
Geebot
694
#54
It would be best to run the cleaner without the pump running so the dirt settles on the floor.
Just like in math class, the question of pump on/off should be followed with an "it depends." There are tons of factors affecting movement of dust/dirt in a pool (e.g. convection currents relating to different temperatures at the surface and below) and simply shutting off mechanical circulation won't cause all the impurities to readily drop to the bottom. The pump/filter captures plenty and the internal filtration process within the cleaner creates its own currents, so while I'd agree that you won't capture everything with the pump on, I'm not so sure you'd be much better off with the pump off.
ping
2,931
Long Beach, CA
#55
I'll keep this in mind and play around with it a bit to see if I see any difference in my pool.
drew1240
4
Roseville/CA
#57
Hello Geebot:
Are you still happy with your S300 cleaner? My Polaris died this month after 3.5 year. So, we are shopping for a new one. I wonder how your S300 is doing since it has been a few year. Thanks a lot!
