Hi,
My dolphin S200 was bought in early 2017, so its warrant expired already.
Overall it worked amazingly until It stopped working 2 weeks ago. Symptom as below:
Turn on power, S200 moves forward for 3-5 feed, then backward for 1 foot, then stops moving completely.
Turn off power then turn on power, same behavior repeats.
Lift out of water and lie upside down, turn on power:
- rotate forward for 3-5 seconds
- rotate backward for 1 seconds
- rotating forward for 10+ seconds.
Seems self test on ground works fine.
Another behavior I notice when it is underwater, no sign out of water movement near the impeller. I remember I used to see obvious water pumped out by impeller, but maybe my memory is wrong.
I also opened cover and found nothing around impeller. Does that imply impeller issue? Is the only way to fix impeller to purchase a whole new motor?
Thanks for any advice in advance.
